Changing a 97 V6 thermostat
Old Oct 26, 2006 | 11:35 PM
jamesbissland's Avatar
Default Changing a 97 V6 thermostat
Hi AllDoes anyone know of a good link with instructions to do this?Thanks in advance,James
Old Oct 26, 2006 | 11:57 PM
dankhound's Avatar
Default RE: Changing a 97 V6 thermostat
Just find a timing belt how to. You might as well do the timing belt, water pump,etc since you have to remove the timing belt to do the thermostat anyway.
Old Oct 27, 2006 | 12:11 AM
John_E's Avatar
At least on the 12V 2.8, the timing belt does not have to come off, but the tensioner near the thermostat housing may need to be slackened. I didn't replace the timing belt and water pump, which had been replaced two years earlier, along with the thermostat. Someone on the PassatWorld forums indicated that some of these thermostats have been unreliable, but I have never had a 2-year-old thermostat fail before. (Thermostat failure at the 8 year mark was what led the first owner to change the timing belt and water pump at that time, as well.)
nutter97
May 11, 2010 09:13 AM
SuperSquid
Nov 12, 2008 06:41 PM
bihoang
Apr 7, 2008 09:50 PM
MiniSpdRcr
Nov 9, 2007 01:44 PM
porscheslave
Oct 24, 2006 07:33 PM
