check engine light keep flashing
Old Mar 23, 2007 | 01:53 PM
razak42's Avatar
Default check engine light keep flashing
I have a 1999 A4 Avant. I purchased gas and did not put my gas cap back on. After a day, the engine started running rough. I bought a new gas cap to put on but it still runs rough. Does anyone know why?
Old Mar 23, 2007 | 02:00 PM
mikeherman's Avatar
Default RE: check engine light keep flashing
I just bought a 2002 A4 QV6. I left the lot and filled it up and put in 87 out of habit. I should have read the gas cap!!!!! The I went 5 days later to fill up and put 94 in it. Ran much better but then i noticed the check engine light on (not blinking). Took it to the Audi joint i bout it from and they put the computer on it and said the code was that there was 'gas trapped' brobably because I did the 87 thing. They cleared the code and it did not resurface.
He told me that not closing the cap correctly or not replacing the cap gives the same code. I hope that helps
Old Mar 23, 2007 | 02:03 PM
akielb's Avatar
Get it vagged (read the codes) and tell us what comes up.
Old Mar 23, 2007 | 02:28 PM
wood_e's Avatar
Take your car to a local auto parts palce and have them read the trouble codes. They should do this for free...
Old Mar 23, 2007 | 11:18 PM
razak42's Avatar
I went to autozone and they detected that it was a misfire in engine 3. I changed the spark plug and the ignition coil but the check engine light still flashes and the engine runs rough. Could someone advice what else?
Old Mar 23, 2007 | 11:25 PM
wood_e's Avatar
Might be the ignition control module. Change the coils around and see if you're still misfiring.
Old Mar 25, 2007 | 11:04 PM
razak42's Avatar
it was the ignition control module. after changing it, it worked fine. thx
Cheno617
Jan 17, 2012 12:07 AM
nyrobe1
Jan 14, 2012 03:59 PM
Peony1955
Sep 16, 2011 06:31 AM
deadmcdowell
Aug 6, 2007 10:29 PM
freeflow
Mar 23, 2006 02:27 PM
