Climate Control
Old Oct 29, 2007 | 10:27 AM
vsilva's Avatar
Default Climate Control
I have newb question. Only had my 98 2.8L A4 for about a week and a half so I'm not even sure something is def wrong.. Got in today (first cold day of the year) and set my temp to 75 auto. When i go to adjust the fans with the manual controls the "auto" label remains on the left lcd even though the man label comes up on the right. I can't get it to stop saying auto unless I shut it all the way off, then come back on. So basically it always says auto once I hit it even though the manual controls work fine. I don't think it was doing this when I first got it. Why is this happening?
Old Oct 29, 2007 | 10:34 AM
SAudi's Avatar
Default RE: Climate Control
try hitting the vent controls, that usually turns off the auto function.
Old Oct 29, 2007 | 10:41 AM
hiwords's Avatar
im in the same situation excpet this is my first winter with this car. just play with it a little bit. u'll get the hang of it.
Old Oct 29, 2007 | 03:39 PM
vsilva's Avatar
Thanks for the quick response. Drove my car at lunch and all is well.
Old Oct 29, 2007 | 04:55 PM
B7QUARTZ2.0T6M's Avatar
I just found out that if you hold down the auto button for about 5 seconds it syncs both sides of the dual climate control. So if you change one side the other side changes with it. I had no idea of this feature. Previous to this I would change one and then change the other to the temp of the drivers side. I always wondered if there was a setting for this...now I know there is!
AnthonySlaughter
Aug 3, 2014 07:27 PM
a8audiv8
Apr 13, 2007 05:33 PM
cian_ie
Jan 10, 2007 07:07 PM
02A4
Mar 27, 2005 10:42 AM
