clutch engagment problem - rode clutch higher revs
Old May 1, 2007 | 10:20 AM
Matt_Iliketurbopull's Avatar
Default RE: clutch engagment problem - rode clutch higher revs
yes that glaze idea sounds like could be it, obviously riding clutch not good and I should get better at not ridin it. But it's just that it seemed to happen so easily, seems others cars I've driven if you rev and ride the clutch that much when take off it never made the clutch become inoprative & at absolute most you might smell the clutch a bit.
I'll try that 5th gear thing soon too
Old May 1, 2007 | 10:24 AM
the comment about it being 'self adjusting' also sounds relevant, how does it work?
Old May 1, 2007 | 10:39 AM
Amze's Avatar
ORIGINAL: kpatz
You probably glazed the clutch, which can make it slip more than usual for a short while until the glazed material wears off, then it should return to normal. But if it slips with your foot completely off it (test by flooring it in 5th gear, FOOT OFF THE CLUTCH and see if it revs up or just bogs), you need a new clutch.
That confuses me...
Ok nm, so your actually driving when you do this? And you just mash 5th, alright.
Old May 1, 2007 | 05:28 PM
kpatz's Avatar
When driving, say around 30 mph, put it in 5th, and let off the clutch and floor it as soon as it engages. If it bogs, the clutch is ok. If it revs up, the clutch is toast.
You could also do it from a stop, but you'll stall the engine if the clutch is good.
dergebirgsjaeger
B7 Models
Aug 10, 2011 10:51 AM
s50swapped
Aug 22, 2008 06:25 PM
kolan67
Oct 25, 2007 03:37 PM
kemp_travis
Sep 20, 2007 12:34 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
