Crank bolt torque spec?
Does anyone have the correct ft-lb torque spec for the crank bolt ona '99 A4 2.8L 30V engine? I replaced the crank seal and want to be sure the bolt/sprocket is torqued correctly.
Thanks!
Thanks!
Avant80@2.6 you out there?
He needs this as well, and I am far away from my manual!
Thanks!
I saw the info for the crankshaft and pulley (thanks!), so I just wanted to verify the correct spec. for the camshaft bolt as well.
Thanks!
