CUSTOM home made intake
Old Jun 19, 2004 | 03:04 AM
Corey Bova's Avatar
Default CUSTOM home made intake
has anybody made a home made air intake>? please post back ideas and what not.. considering doing this!
corey
Old Jun 21, 2004 | 03:18 AM
SlimChriz's Avatar
Default RE: CUSTOM home made intake
aaah yeah I have ...well no I didnt but I tried
Im about 3/4 the way through one right now but its been that way for about 8 months I made it by using three inch steel tubing and for the corners I cut the tubing in slices at an angle and used as many slices that I need to make the turn and welded them together..... the problem for me is that my welder is 50+ years old and overheats then it grounds out through the cement (very uncomfortable) so the only way to use it is in short intervals. Which means itll never be finished, also a problem I forsee is all the vacuum lines and sensors an stuff will be a bitch to incorporate into the finished piece not impossible but but it means that it will probly just sit in my garage collecting a nice coat of surface rust[&:]
yeah so maybe you should chose another media to work with unless to have the equipment to make it less of a pain in the *** than what Ive had...like a mandrel tube bender or modern welding apperati ....good luck
Old Jun 21, 2004 | 10:26 AM
Corey Bova's Avatar
thanks for the info Slim yea im going to keep searching for ideas and whatnot. post back more responses and ideas please! thanks
corey
Old Jun 23, 2004 | 01:16 AM
xxaudia4driverxx's Avatar
Hey all this is my first post I think this may helpCustom Intake you with you custom intake:
Old Jun 24, 2004 | 05:52 PM
1.8TQUATTRO's Avatar
just dont do it like this guy i used to know that made an intake for his civic hatchback with chicken wire and a coke can, talk about one screwed up engine...
Old Jun 25, 2004 | 10:35 AM
Corey Bova's Avatar
thanks everybody for ideas and whatnot
corey
Old Jun 25, 2004 | 04:13 PM
ImolaS4's Avatar
After all the setbacks and time away, I'll be able to post pics of the custom ram-air intake that I made. I'll get them up this weekend.
Old Jun 26, 2004 | 11:41 AM
Corey Bova's Avatar
thanks, sounds good
corey
tofast2belast
May 30, 2013 07:48 AM
DillonT
Nov 30, 2012 11:30 AM
bradtyler02
Jul 20, 2010 10:18 AM
ARIaudiS4
Dec 3, 2007 10:15 PM
auditt225
Mar 18, 2007 10:35 PM
