Debadging Help!! UPDATED!!
Old Oct 4, 2007 | 12:03 AM
hiwords's Avatar
Default RE: Debadging Help!!!!
dats a no no. nvr put anything visibly sharp to ur exterior. u cn hand buff it but i think in ur case u would be spending hours on it if it's not glue that ur dealing with. to do the whole job right, buff it, and the some meguir's show room glaze will make ur car shiny as hell
Old Oct 4, 2007 | 12:05 AM
turbo kraut's Avatar
Tech Guru
ORIGINAL: Lazer Viking
wet sanding is the only thing to get it off
its very difficult to get perfect on a dark car, and even at the right angle you can still see where mine were,
+1 on wet sanding and still seeing it
get the finest grit you can though, if you go too rough you will sand through the paint and clear, you mainly just wanna sand down the clear
and at the right angles you can see my emblems inbeded into the paint and a faint outline, kind of same deal you have, but i have the ebony pearl and they are a itch to keep clean
Old Oct 4, 2007 | 01:00 AM
ocadam's Avatar
I debadged my black car i kinda had the same problem.. Did you try HOT i mean HOT not warm and some soap then scrub it like a Mother.
Old Oct 4, 2007 | 01:37 AM
turboAUDI77's Avatar
damn i have the same problem but i have a B5. i have a porter cable and i buffed out the marks in a couple seconds.
Old Oct 4, 2007 | 03:14 AM
sdboarder84's Avatar
try brake clean. I had the same marks on my car and my buddies car when we debadged them. It took it off in to seconds.
P.S. it will not hurt your paint if you put the Bbrake clean on a rag and then rub it on.
Old Oct 4, 2007 | 08:28 AM
skindiggler's Avatar
I had the exact same problem ,thin outlines and they look stupid. Let me know if you have any luck because i have the same problem.
Thank you
Old Oct 4, 2007 | 10:44 AM
ironman's Avatar
i had that i used googone and open the trunk sprayed uit and let it sit for like 3 hours came back and rubbed like crazy car looks mint now, turtle wax will work well to make sure its a warm day and rub like crazy
Old Oct 4, 2007 | 11:14 AM
  #18
AudiVirgin's Avatar
I had the same problem! Wet sand it and it will be good as new! It is very easy to do and will take all of 5 min! I did mine like this last week and looks great now! Make sure you use 1000-1200 grit sand paper and soapy water to wet sand with then buff out! Very Simple!
Old Oct 4, 2007 | 02:02 PM
  #19
smokeU's Avatar
first of all take a picture from about 3 feet back. So we can see what you're dealing with.
Old Oct 4, 2007 | 07:08 PM
  #20
a4ultra's Avatar
I cleaned it up and looks a lot better now! Thanks for the help guys
shady927
May 10, 2008 06:05 PM
paylesspb
Oct 10, 2007 01:31 PM
Jestnomen
Mar 10, 2006 11:05 PM
40vV8
Mar 1, 2006 02:35 AM
Persmacky
Jul 20, 2005 06:58 AM
