Driver's door problem
Anyone had problems with their outside door handle suddenly not doing anything? I just went out to start and warm up my car and after I unlocked the car, I went to open the door and it's like the handle isn't connected to anything. WTF? There's no sign that someone messed with my car last night (and in my neighborhood, that's basically as unlikely as can be). It worked fine last night, but today it's like the outside handle was never connected to the unlatching mechanism at all. The inside handle worked fine, and I could open the door from the other side. Anyone fix this before? I had this happen on a POS winter beater once and it turned out to be a bent actuator rod inside the door, but I'm curious if it's happened to anyone on their A4. Any particular part that seems to fail and cause this on these cars? For now at least I can open the windows with the remote and open my door that way but that's gonna get old really fast. When I searched it I found (among other things) someone who had this problem on their A6, and it was mentioned that a piece probably broke inside the door, which disconnected the handle from the mechanism. I can believe that, but I sure didn't hear anything or feel anything break when I lifted the handle. TIA for any insight.
yeah mine did this, just take the door panel off, its really simple, its 3 or 4 little screws then you lift up on the whole panel. and just take a look in there, my passenger door handle was simply disconnected nothing broke, just the clip connecting the handle with the cable to unlock the door came off.
ya my drives door did that about a month ago but it only didnt open from outside, inside u could still open the door with no problem. it only happend once and it was really cold that day and the day before it was rainning
That's pretty much how it was here too - cold last night with some snow/rain. I opened the door from inside, warmed up the car, and when I came back out the outer handle worked fine. Most likely as you guys have hinted at, it was something to do with either the lock or latch mechanism and the cold. Once the car was warm, it was fine, and the problem didn't reoccur. Thanks for the feedback - when it warms up sometime I'm going to take the panel off and see what I can do to massage the linkage.
i don't think weather stips are covered but you can always callthem up to check. it's that black horizontal piece right acros the whole window. get it fixed fast because water could destroy everything inside that door.
I have a weird problem, my two front doors open fine from the inside and if they are not locked from the outside but when I lock them, either with the remote or the key, and then I try to open the doors, they remain shut until I hit it right above the door handle and then it opens fine. This happens to both front doors, back doors are fine
H E L P
H E L P
ssingh
Jan 8, 2012 11:13 AM
