Dual Rear Fogs
Old Oct 17, 2007 | 02:39 PM
cantdrive55's Avatar
Default Dual Rear Fogs
So I'm trying to get it so I can have dual rear foglights. I'm not going to use them for their intended purpose but only when there are those complete a-holes who are tailgaiting me at night with their high beams on. So I dremeled out the top hole for the bulb and tossed a new one in, flip on the rear fog switch, and...
NOTHING! The rear left fog turns on but not the right one. I've read up on a bunch of people who have just rounded out the socket and then get a bulb and it turns on. I'm not sure what's up but if anyone has any suggestions let me hear 'em.
Old Oct 17, 2007 | 02:46 PM
kriptonik's Avatar
Default RE: Dual Rear Fogs
I don't use dual rear fog but I took out the right side once, put in a bulb and it worked fine.
I think it could be a wiring problem on yours, which I am not familiar with.
Old Oct 17, 2007 | 02:48 PM
qUaTtRoA4's Avatar
Old Oct 17, 2007 | 02:52 PM
techbod's Avatar
in the UK its normal to have both fogs and simple to fit if you don't ( the wiring is already there ) all you need is the bulb and plug
Old Oct 17, 2007 | 03:03 PM
qUaTtRoA4:
I am just looking to bring on the right hand side fog light. Not trying to do the whole super duper rear brake lights mod as those links show.
techbod:
I know it's supposed to be just that simple and that is what I have done. I just put a bulb in and it didn't turn on with the rear fog turned on.
Old Oct 17, 2007 | 03:05 PM
hiwords's Avatar
yell at it and tell it u'll ground it for a week lol. test the wires on the assembly and see if ur getting power to it.
Old Oct 17, 2007 | 03:15 PM
techbod's Avatar
the rear fogs have a complete unit and the wiring should be there to plug in but failing that its a 2 wire thing to connect the left with the right and all you need is the bulb plug in and the Audi 90 has that
Old Oct 17, 2007 | 04:00 PM
So I just went out and checked for which wire I have power from. When you look at the entire module with the plug at the bottom the only wire from which I have power is the 2nd from the left. Which goes in conjuction with the other brake light mods. So are most people just able to put a bulb in and then it comes right on?
Old Oct 17, 2007 | 04:11 PM
hiwords's Avatar
did u turn on the lights b4 u checked it? and ya mine was just make a whole, pop in bulb and go
Michael Steven Torres
Sep 1, 2012 08:52 AM
B7 Models
Aug 31, 2012 10:33 AM
jcA4Quattro
Jan 5, 2012 08:06 PM
edepaolo
Sep 4, 2010 12:54 PM
danmcc86
Oct 12, 2009 11:07 PM
