Emissions help!!
I have a 1998 A4 2.8 Quattro with almost 130K on the clock. I need to get an emmisions test to register my car again. I have taken it to be tested once and failed miserably. My hydro carbons were reading 4 times the legal limit in ABQ, NM. I recently replaced my air filter and timing belt. What usually causes these vehicles to fail an emissions test? I wonder could it be the O2 sensor? Or maybe the spark plugs? Any help is very much appreciated.
Have you run a VAGcom and seen what codes are stored?
Could be anything from a bad precat oxygen sensor, fouled or worn plugs, leaky injectors, misfires, bad ignition coils, bad ignition controller, etc
