Emissions help!!
Old Oct 27, 2005 | 04:57 PM
ImAudi's Avatar
Default Emissions help!!
I have a 1998 A4 2.8 Quattro with almost 130K on the clock. I need to get an emmisions test to register my car again. I have taken it to be tested once and failed miserably. My hydro carbons were reading 4 times the legal limit in ABQ, NM. I recently replaced my air filter and timing belt. What usually causes these vehicles to fail an emissions test? I wonder could it be the O2 sensor? Or maybe the spark plugs? Any help is very much appreciated.
Old Oct 27, 2005 | 06:13 PM
CRAZYHAWK's Avatar
Default RE: Emissions help!!
Hydro-carbons could be high do to a faulty ignition system. Spark plugs and wires could cause this.
Old Oct 28, 2005 | 04:42 PM
ImAudi's Avatar
I will change the spark plugs and see if that works, otherwise I will have to see if my ignition is the problem. Thanks for your advice CRAZYHAWK.[sm=smiley20.gif]
Old Oct 28, 2005 | 05:09 PM
beefski's Avatar
use good plugs and wires
NGK plugs and oem wires.
also u could tyr some fuel system cleaner, gumout regane
Old Oct 28, 2005 | 09:24 PM
CRAZYHAWK's Avatar
Fuel mixture problems cause high CO readings.
Old Oct 28, 2005 | 09:58 PM
Shaunp05's Avatar
H.C is pretty much raw fuel or more fuel is been used
I would look at ignition first if everything seems ok
the have a look at wat your O2 are reading....
the pretty much tell the whole picture
Old Oct 29, 2005 | 12:56 PM
david9999's Avatar
Have you run a VAGcom and seen what codes are stored?
Could be anything from a bad precat oxygen sensor, fouled or worn plugs, leaky injectors, misfires, bad ignition coils, bad ignition controller, etc
betes
Sep 7, 2010 04:33 PM
AudiRy05
Oct 7, 2008 05:56 PM
1.84life
Apr 29, 2008 10:49 PM
RIA6
Sep 14, 2007 09:06 AM
dubiousmusic
Mar 1, 2006 09:03 PM
