engine noise
Old Sep 18, 2004 | 03:45 AM
KloepferN's Avatar
Default engine noise
today i was hearing this high pinch noise coming from my engine i really couldnt find where it was coming from, it was at night. does anyone have any clue of what it could be???
Old Sep 18, 2004 | 10:34 AM
Jestnomen's Avatar
6th Gear
Default RE: engine noise
We need more information than that to help you. Did the squealing occur when you were turning? Was it at low speeds? Could be low power steering fluid. Could be timing/accessory belt going bad, or it could be a wheel bearing.
Old Sep 18, 2004 | 05:51 PM
brrman's Avatar
yes - more info about when you hear it. Right after startup, when you turn the wheels, etc? How loud is it?
Old Sep 19, 2004 | 01:24 AM
Transverse's Avatar
I have a similar issue. My engine started makin this high pitched noise about a week ago. It happens when I lift my foot off the accelerator and the RPMs drop down. Doesn't really matter how high the rmps are..just the slow down of the engine causes it. I tried to pin point where it was coming from and it sounded like middle of the engine compartment right infront of the firewall...so I don't think its the turbo or the DV makin the sound..but my ears could be tricking me..
The volume is audible over the engine dropping in RPMs enough to hear it faintly while driving. I actually thought it was coming from the rear right wheel..but I had my friend stick his head out the window tonight to check where it was. We proceeded to check after stopping the car and popping the hood.
Any idea?
Old Sep 19, 2004 | 01:36 AM
David_K's Avatar
there is a cam timeing chain in the middle rear of the engine. if it coming from the back of the engine thats not good. it means its inside the engine or its some control inside the cabin.
Old Sep 19, 2004 | 05:22 AM
KloepferN's Avatar
naw the car was park and i was talking to someone and it just made this low pinch sound like maybe a belt, kinda sounded like a/c belt or something[:-]
Old Sep 19, 2004 | 09:56 AM
Jestnomen's Avatar
6th Gear
Could be your accessory belt or timing belt getting ready to go? I'd have it looked at, that's pretty serious stuff.
Old Sep 21, 2004 | 03:21 AM
KloepferN's Avatar
anyone knows how much that would be to look at?? anyone know any good place in orlando??
jraffoul
Apr 10, 2017 06:10 AM
kenman
Sep 12, 2012 02:34 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
