engine noise
Old May 28, 2007 | 02:33 PM
misseswinky's Avatar
Default engine noise
amp and sub installed...engine noise comes on ONLY when headlights are on...any ideas?
Old May 28, 2007 | 02:35 PM
ironman's Avatar
Default RE: engine noise
your power must be getting interfernce from the lights, if you run zenons that alot fo jiuce.
Old May 28, 2007 | 05:12 PM
00A41.8Quattro's Avatar
My buddy just ran into this problem not too long ago. Try checking all of your grounds. The best ground is your key n the ignition. Try touching it to everything that you just installed. Run a piece of wire from your key to whatever you installed. Because it sounds like a bad ground.
jraffoul
Apr 10, 2017 06:10 AM
kenman
Sep 12, 2012 02:34 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
