Started my car the other night, Engine started making this noise, like the belt was scratching on something, what could it be? i just replaced my timing belt and all the components and serpertine belt but that was about a month ago and jut started doing thins noise.
http://s59.photobucket.com/albums/g3...t=CIMG2020.flv
Make sure nothing is rubbing either, and double check the belt tension.
How many miles are on it? Sounds like the water pump pulley is hitting the timing belt guard, it wouldn't suprise me if you were right at the 80k mark.
94k? Have you don't the timing belt yet, cause your skating on thin ice.
yes i replaced everything timing belt rollers ect serpertine belt... well i found out what it was my serpertine belt broke today. one of the rollers was shaking was not installed correctly and broke
