Erratic starting on 2001 A4 Avant
Old Feb 1, 2007 | 03:16 AM
graeme's Avatar
Default Erratic starting on 2001 A4 Avant
I am battlingwith erratic starting on our 2001 A4 Avant (1.8) .
The problem is that theengine turns but doesn't take. It will often start a few minutes later. We thought the problem was the battery and therefore just replaced the battery but the problem persists.
Sometimes jump starting helps (but only off a car with a decent battery) and other times push starting helps.
I have taken the car to Audi (they did some work on the throttle control) and just yesterday took it to a workshop who read the computer but couldn't find any fault.
In desparation, I added some inector cleaner to the fuel tank but this doesn't seem to be the problem.
I would apprecaite any comments or advice.
Thanks
Graeme
Old Feb 1, 2007 | 03:28 AM
tractioncontrol's Avatar
Default RE: Erratic starting on 2001 A4 Avant
Have you looked for broken vaccume hoses? What did they do to the throttle control, a clean and adjust or just one or the other?
Old Feb 1, 2007 | 10:15 AM
graeme's Avatar
Hi there and thanks again for the help.
They billed me for adjusting and cleaning the throttle body.
I am technically challenged. Can anyone recommend a website that will explain how to find the vaccum hose and how to check for leaks?
Thanks again
Graeme
Old Feb 1, 2007 | 12:19 PM
CRAZYHAWK's Avatar
On the left side of the engine, between the intake manifold and
the G-12 reservoir, there is an L shaped vacuum hose. Check
the elbow for tears.
Old Feb 1, 2007 | 12:25 PM
graeme's Avatar
Thanks. I will check it
Prof Requiem
Jan 29, 2023 04:32 PM
kevinruswick
Jan 4, 2011 07:21 AM
CoreyJ
Dec 10, 2010 09:19 AM
mcclellandm
Jul 21, 2010 01:53 PM
Scotts
Aug 29, 2006 12:18 AM
