fitting abs sensor
Old Sep 15, 2006 | 09:02 PM
harryc's Avatar
Default fitting abs sensor
can anyone offer advise.
I have damaged the front offside sensor .(Having taken off the hub to have a wheel bearing fitted.)
The ABS light is now on!
The sensor is very difficult to remove from hub and also I was wondering where the cable goes too throught the wheel arch?
Any help would be appreciated.
Old Sep 15, 2006 | 10:24 PM
Mike@PureMS's Avatar
Default RE: fitting abs sensor
There is a single screw holding the sensor to the spindle. Remove that, and the sensor should come out. It will be tough to pull out, especially if you lift in an area with lots of salted road.
It helps to use a penetrating oil like PB Blaster.
Old Sep 16, 2006 | 03:33 PM
harryc's Avatar
no screw on my A4 1998 TDI
I have the job completed.
The connection was easily found through the wheel arch
ORIGINAL: Mike@PureMS
Old Sep 16, 2006 | 03:37 PM
techbod's Avatar
glad you got it sorted ABS is a pain
edit: in most cases you have to knock the old sensor out after undoing the 10mm bolt because it rots in the hole so you can almost guarantee it will be damaged on removal, and all you had to do was follow the wiring to find the connection
Old Apr 17, 2013 | 02:58 AM
gfilippidis's Avatar
Default Cannot find the connector
Can someone explain me or post a picture of where the ABS sensor connects? I had no problems taking it out but cannot find the electrical connection.
thanks
PaulEnglish
Feb 12, 2011 12:47 PM
sa9023
Dec 9, 2010 12:31 PM
viper9821
Jun 7, 2007 10:59 AM
tommygn
Aug 16, 2006 04:57 PM
Sam*
Jan 23, 2006 08:48 AM
