fliud leak?
Old Jul 6, 2007 | 01:32 AM
jimmyt853's Avatar
Default fliud leak?
wuts up guys. i noticed last night my power steering fluid was almost completely empty annd it started making a noise. this happened to me before. and i did the fluid flush and bled the fluid back through. but the fluid i used today was different than the past 1 i had used. the part number was different, but i got it ffrom the audi dealer and he sed this was the new replacement for it . so i did the flush and bled it back through and the noise stopped. also when i did this i topped off my antifreeze, but i may have filled it up too much.
so, later in the day after driving for a little while i noticed the noise had came back. i checked the ps resevoir and it was close to empty again. so, i redid the process. after i did this, i noticed there was a fluid leaking. but, the spot on the ground wasnt under the ps resevoir. it was towards therear middle of the engine.
so, my ps fluid is getting drained by itself, and there is a leak of an unknown fluid in a different spot of the ps resvoir.
can any help????
Old Jul 6, 2007 | 01:48 AM
auditech79's Avatar
Default RE: fliud leak?
If the fluid is clear it is the power steering fluid. Your gonna have to rack the car and turn the wheel lock to lock and see where the fluid is coming from. NOTE: audi power steering fluid is a mineral based fluid that evaporates very quickly and should be topped off every oil change or 5k.
Old Jul 6, 2007 | 07:41 AM
ironman's Avatar
where is the Fill level on a PS res. i looked and i didnt see one, i want to top mine off but i want to see what i need first and about how much i am going to need.
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
inventorA6
Apr 15, 2009 06:46 AM
murderda6
Jan 17, 2009 01:02 PM
