Fog light issue as well
Old Dec 27, 2006 | 12:49 PM
khaoswing's Avatar
Default Fog light issue as well
In need or more advice guys, I'm gonna get working on the throttle body later. (who ever is following my post)...anyways..I do havea seperate issue. two weeks ago my Fog light for my A4 2.8q (1998). both of the lights where no working..so i went to the local parts store and bought two Silver Start H1 bulbs, changed it.."the old bulbs were burnt"..but when I hopped in the car to try it out..it still doesn't work.. please help...(the indicator button in the car does not light up-u know the yellow and green light ) front & back fog lamp button.??? help??
Old Dec 27, 2006 | 01:58 PM
ImTheDevil's Avatar
Default Try this...
Do you have a handheld digital multimeter/voltmeter? If not, get one (around $10 for one at the auto parts store). Install fog bulbs and plug them into the harnesses. One wire will be a ground, and one will be electrically hot. With the switch turned on, probe both wires/contacts, and see if you're getting voltage to the bulbs. Chances are, it won't work and you won't find voltage at either wire (if you did, the bulbs would light up unless they were both blown, but since yours are new, they shouldn't be). If no voltage is present, either your fuse is blown or your relay is not working right (or an outside chance - there's a broken wire somewhere or you have a bad switch, but I seriously doubt either of these). I don't know the location of the foglight relay, but find it, and with the switch turned on, tap it moderately with a wrench or other soild tool. Mechanical relays can stick sometimes, and doing this can get them to latch. If you find that it's not working even after tapping it, take another relay from somewhere else and swap it in. There should be information on the relay itself as to current ratings and such - make sure to use another relay of the same rating. If they then work, then you've proven that the relay is bad. Take your original fog light relay, plug it into the location that you pulled the other one from, and make sure that system now will not work (confirmation that the relay itself is bad). Get a replacement and you're good to go.
Old Dec 27, 2006 | 02:35 PM
khaoswing's Avatar
Default RE: Fog light issue as well
i'll give it a try..thanks for the advice
audiS4jls
Apr 7, 2012 11:05 PM
paulywalnuts446
Feb 9, 2010 12:30 PM
osterthetoaster
Feb 25, 2008 01:12 PM
kraylon
Mar 28, 2006 07:47 AM
SteelCitySupra
Nov 27, 2004 05:51 PM
