Fuel Pressure Weirdness
Old Mar 30, 2013 | 07:44 PM
jackcarrozzo's Avatar
Default Fuel Pressure Weirdness
I've been getting the engine code for "Multiplicative Fuel System Too Lean" for some time now. I have verified that I'm not getting any unmetered air in.
Today I replaced the fuel pressure regulator on the injector rail, and also added a connection for a fuel pressure gauge. Unfortunately I didn't get a reading with the old regulator, but with the new one installed I was getting 3.1 bar with the vacuum hose on the regulator connected properly, and 3.8 bar with it disconnected.
According to the specs I've seen, my engine code uses 4 bar fuel pressure into 284cc/min injectors (also, my FPR is stamped 4bar).
- Should I assume that I have either a clogged fuel filter or bad fuel pump since I'm getting lower?
- Is there supposed to be a check valve on the vacuum hose from the FPR to the manifold such that only ambient or boost pressure gets to the regulator? It seems like the vacuum connected as I have it takes the pressure down quite a bit, though that may be on purpose to make idle injector PWM more fine-grained.
FWIW, the car is a 2001 A4 quattro wagon 1.8t.
Thanks!
Old Apr 1, 2013 | 11:30 PM
Expplucky's Avatar
the injectors are pretty known to go bad (or so im told) and im pretty sure the inector sets are cheaper than the fuel pump! have u used an addative to clean the injectors? maybe try the additive and use the shell vpower drive about 30miles highway and see if that helps. if it doesnt i would just swap the injectors out.
Old Apr 2, 2013 | 11:44 AM
Ah I should have mentioned: yep, the first thing I did after an air leak check was to replace the injectors, then the MAF and MAP.
Old Apr 7, 2013 | 05:38 PM
Expplucky's Avatar
fuel filter might have a hand in the problem
vtraudt
May 9, 2011 11:08 AM
diggs
B7 Models
Jul 31, 2010 12:09 PM
kerNol
Feb 25, 2009 09:53 PM
im timmy
Aug 3, 2005 10:10 PM
dons_one
Jan 27, 2005 03:20 PM
