gapping spark plugs? doesnt make sense
Old Jun 20, 2006 | 02:16 AM
  #21
rnbguy's Avatar
Default RE: REgapping spark plugs? doesnt make sense
im just gonna try .030 as 0.028 seems like its for a bigger turbo and the neuspeed chip isnt that powerfull
Old Jun 20, 2006 | 11:45 AM
  #22
JettaRedII's Avatar
ORIGINAL: rnbguy
A lot of things go into making a chip "powerful", not just boost. If you are boosting a 1 bar or more (15+ psi), you want to keep your gaps tight or you will be replacing the coils soon.
Old Jun 20, 2006 | 11:53 AM
  #23
rnbguy's Avatar
sweet thanx
ill try .028 what are signs that show i should loosen the gaps?
also i see uve got a 1 bar neuspeed chip too, did u change ur FPR?
Old Jun 20, 2006 | 02:40 PM
  #24
rnbguy's Avatar
well i did it, changed em and regapped em to .028 (i was a little impatient and used the cement floor to close the gaps which scratched it a bit but that doesnt matter) anyway, no more stuter!!!!!!
i also found oil in there which im guessing was bcuz i had a leak valve gasket cover which i fixed with spark plug covers too... all good now
extra thank you for your help
if i had put the coil pack in wrong order whicih i doubt would i notice it when driving?
Old Jun 20, 2006 | 04:13 PM
  #25
CRAZYHAWK's Avatar
0.028 inches = 0.071 cm
0.030 inches = 0.076 cm
  #26
JettaRedII's Avatar
ORIGINAL: rnbguy
sweet thanx
Yes, I put the 5 bar fpr in, per Neuspeed's recommendation. However, I've run it with the 4 bar with no problems. Neuspeed recommends the 5 bar because Aaron Neuman, who does the programming, doesn't like running the fuel injectors at capacity. However, with the 5 bar, you're going to see long term fuel trims in the -10% range.
DanaB6
Jul 7, 2012 01:39 PM
kchao2000
Nov 10, 2009 01:41 AM
Armenian
Jun 29, 2007 12:26 AM
a4autocrossr
Aug 2, 2006 05:28 PM
mlo517
Jul 1, 2005 07:34 PM
