having issues...
New to the forum and new to the world of audi. Just picked up a '97 2.8l quattro 5spd. Beautiful car... Anywho, I'm drivin along a few days after buyin it, and i go to downshift. Upon depressing the pedal, i find it falls right down to the floor. after a quick freak out i find i can pull it back up with my toe. while its down, the clutch is still engaged so i have to pull it out of gear. needless to say this was kind of distressing. i keep driving figure its nothing big. It happens again maybe an hour later. Since then it happens more and more frequently, im guessing some kind of hydraulic valve is clogged or worn or something.
i also get a little shudder in the drivers side front wheel when pressing lightly on the brakes. normally i wouldnt be concerned but there is also a squeak coming from the suspension on the same side.
Probably/hopefully nothing but if you guys know anything please fill me in.
i've had it for about 2 weeks, so ive got another 2 to get it back to them to fix it. It's actually goin in for the clutch thing tomorrow, i just want some kind of heads up on what it might be.
Re: the clutch thing, I had the same problem on my Eclipse a few years ago. One of the pipes in the hydraulic clutch system broke and the fluid was leaking out (so pressure was low, that's why the pedal got stuck down). I ended up replacing the pipe and everything turned back to normal... for a while.
After that, actually, I had issues with that hydraulic clutch seevral more times. Everything from replacing the slave cylinder to replacing the master cylinder... it was a pain. Hope you will be more lucky!
