having issues...
Old Aug 7, 2005 | 03:53 PM
Schwartz2.8///'s Avatar
Default having issues...
New to the forum and new to the world of audi. Just picked up a '97 2.8l quattro 5spd. Beautiful car... Anywho, I'm drivin along a few days after buyin it, and i go to downshift. Upon depressing the pedal, i find it falls right down to the floor. after a quick freak out i find i can pull it back up with my toe. while its down, the clutch is still engaged so i have to pull it out of gear. needless to say this was kind of distressing. i keep driving figure its nothing big. It happens again maybe an hour later. Since then it happens more and more frequently, im guessing some kind of hydraulic valve is clogged or worn or something.
i also get a little shudder in the drivers side front wheel when pressing lightly on the brakes. normally i wouldnt be concerned but there is also a squeak coming from the suspension on the same side.
Probably/hopefully nothing but if you guys know anything please fill me in.
Old Aug 7, 2005 | 03:56 PM
Jestnomen's Avatar
6th Gear
Default RE: having issues...
how long have you had the car? I would take it back to the company/dealer you bought it from.
Old Aug 7, 2005 | 03:59 PM
i've had it for about 2 weeks, so ive got another 2 to get it back to them to fix it. It's actually goin in for the clutch thing tomorrow, i just want some kind of heads up on what it might be.
Old Aug 7, 2005 | 04:03 PM
BaconBait's Avatar
The shuddering you feel is most likely warped brake rotors.
Old Aug 7, 2005 | 04:17 PM
david9999's Avatar
Sounds like the accelerator cable is binding somewhere.
Reminds me of the old Audis, you know, the ones that would suddenly jump out of park and accelerate? Shades of the late 70s
Old Aug 7, 2005 | 08:44 PM
Muchnik's Avatar
Re: the clutch thing, I had the same problem on my Eclipse a few years ago. One of the pipes in the hydraulic clutch system broke and the fluid was leaking out (so pressure was low, that's why the pedal got stuck down). I ended up replacing the pipe and everything turned back to normal... for a while.
After that, actually, I had issues with that hydraulic clutch seevral more times. Everything from replacing the slave cylinder to replacing the master cylinder... it was a pain. Hope you will be more lucky!
tofast2belast
Sep 19, 2012 06:08 PM
ImTheDevil
Aug 3, 2011 09:11 PM
awk81
Jan 10, 2007 02:56 PM
rfors777
Jun 17, 2006 12:26 AM
kenestle
Dec 4, 2004 08:31 PM
