Head rebuild update and ?
Old Dec 11, 2007 | 10:06 PM
cincyTT's Avatar
I'm make believe
Default RE: Head rebuild update and ?
The rods are connected by 2 bolts, forget what fitting. Crank can be access from underneith with the oilpan removed. Just disconnect them from the bottom and push the up through the top. 034 only sells Scat rods, you need IE (intergrated engineering) rods. They make 19mm pin rods and so does Pauter, but those are $1k.
Old Dec 11, 2007 | 10:09 PM
cincyTT's Avatar
I'm make believe
Those them. They are cheaper here at 20squared
Old Dec 11, 2007 | 10:15 PM
khj677turbo's Avatar
Awesome, i figured thats what i had to do. If you dont mind me asking, could i have a readers digest version of what a SCAT rod is? Not understanding the diff. is it a compression change? I checked google but its useless.
Also, why are the IE's so much cheaper then everything else i have run into?
Old Dec 11, 2007 | 10:21 PM
cincyTT's Avatar
I'm make believe
Scat is a company and makes the 144/20mm pin H-beam rods where IE makes them for 144/19mm rods since no one else really did. Both are in the $350 range where Carrillo and Pauters are $800-1200. The scat and ie rods will be fine for cars making in the 600whp range where the others car probably hold in the 800whp+ range. The only downside to the ie rods is that you have a weaker 19mm pin where the AEB/ATC/AWD/225's all use 20mm pin pistons that are a little stronger. There have been a good amount of people running IE rods and making 400-500whp already.
Old Dec 11, 2007 | 10:27 PM
Ok thanks cincy, ill have better updates when i go home this weekend. But if im going through with dealing with the bottom end ill be ordering up some IE's
Thanks again
Old Dec 11, 2007 | 10:32 PM
cincyTT's Avatar
I'm make believe
np. But dont forget the rings if you hone the cyl's
Old Dec 11, 2007 | 10:42 PM
Machine shop will deal replace them when they hone right?
Old Dec 11, 2007 | 10:52 PM
  #18
cincyTT's Avatar
I'm make believe
if you pay them they might. But you should bring the rings.
Old Dec 11, 2007 | 10:53 PM
  #19
Do you suggest honing the cylinder on my own? Also, how hard is it to drop the oil pan?
  #20
cincyTT's Avatar
I'm make believe
i would let a machine shop do it personally. Dropping the pas shouldnt be to hard. Auditech79 should know the preceedure off the top of his head
AudiTurbo
Jan 7, 2014 08:03 AM
dmount76
Feb 3, 2013 01:13 PM
PistonNut
Nov 21, 2011 08:19 PM
khj677turbo
Dec 17, 2007 09:37 PM
David_K
Sep 11, 2004 12:54 AM
