headlamp cleaning
Old Jan 22, 2008 | 10:02 PM
bronxblaza117's Avatar
Default headlamp cleaning
noticed my left headlight was dimmer than the right. went to check it out and noticed the projector is really dirty. how do i got about cleaning the projector? do they just screw out of the headlamp assembly?
Old Jan 22, 2008 | 11:44 PM
ImTheDevil's Avatar
Default RE: headlamp cleaning
There's another thread about this currently being discussed. Take a look there - I put up a post on how I did it on another car and it shoudl work for yours too.
Old Jan 22, 2008 | 11:49 PM
ImTheDevil's Avatar
Here's a direct link:
https://www.audiforums.com/m.asp?m=7...age=1&key=
Old Jan 23, 2008 | 12:12 AM
um ok. do the projectors just screw out? all you said was that i can be done, i was looking more for how. I have a B6 A4, halogen projector headlight.
Old Jan 23, 2008 | 12:37 AM
ImTheDevil's Avatar
No, I mean remove the whole headlamp from the car - the whole thing, housing and all, and then go into the projector through the bulb mounting hole.
Old Jan 23, 2008 | 12:45 AM
ohhh ok. so this only gets the back of the projector though right? mmmhhh. trying that out tomorrow
Old Jan 23, 2008 | 12:50 AM
01A4T's Avatar
Im not sure if they un screw from the housing, as I believe they are all one sealed housing. After quite a few years, the housings can get a little cloudy(reducing light output).I ended up going the expensive route on my B5 by buying a whole new housing from the stealership which cost me about 600 bucks. But I prettymuch had to because my other side housing was damaged and replaced by insurance. My advice would be to take the housing out(which is a huge PITA) and trial and error it to see if the projector comes out. Goodluck man.......
Old Jan 23, 2008 | 12:55 AM
well i had to take the housing out to install my HID's last week. the first time was the hardest because i didnt really know what to do, i should have it down packed now, having taken it down 2-3 times. will give it a rub with some rubbing alcohol tomorrow. thanks.
moeron7
May 1, 2011 01:38 AM
jj2345
Oct 29, 2009 12:14 AM
vw754
Sep 5, 2007 12:03 AM
clash8488
Jan 31, 2007 08:09 PM
Greyster
Mar 16, 2006 01:36 PM
