Headlight Washer
Old Jan 24, 2007 | 12:07 PM
mkunert's Avatar
Member
Default Headlight Washer
My left side headlight washer is not working. I replaced the pump last year, and they both worked fine. The first time I used them this year, the left side failed to pop up, but the right side worked. Any ideas why one side would work, and one not?
1998 A4 1.8T
Old Jan 24, 2007 | 12:19 PM
b_coulombe's Avatar
Default RE: Headlight Washer
I dunno man,
mine have never worked. nota once. I never figured it out.
Good luck
Old Jan 24, 2007 | 01:53 PM
akielb's Avatar
Just so I understand
The left side doesn't work at all or just doesn't pop up and you see dripping washer fluid below the car.
if nothing - then its most likely just a clogged line or somthing simple like that
Old Jan 24, 2007 | 02:42 PM
wood_e's Avatar
I've got a headlight washer if you need it. I removed mine a few months ago.
Old Jan 24, 2007 | 03:37 PM
BFlan2001's Avatar
the washers are raised hydraulically so if it's not coming up it's not getting enough pressure. the fact that you see fluid dripping underneath most likely means theline is partially clogged somewhere
Old Jan 24, 2007 | 03:59 PM
mkunert's Avatar
Member
No fluid comes out. It must be clogged. I wasn't sure if it's hydraulic or electric. I assumed hydraulic. I'll dig into it this weekend. Thanks.
mcanedo92588
Jul 1, 2013 11:27 PM
twilliams83
Apr 2, 2011 07:47 AM
Quaberto
Sep 20, 2006 10:08 PM
cdnskier
Jan 7, 2006 11:12 PM
A4orced
Aug 22, 2005 07:08 PM
