Headlight Washer
My left side headlight washer is not working. I replaced the pump last year, and they both worked fine. The first time I used them this year, the left side failed to pop up, but the right side worked. Any ideas why one side would work, and one not?
1998 A4 1.8T
1998 A4 1.8T
Just so I understand
The left side doesn't work at all or just doesn't pop up and you see dripping washer fluid below the car.
if nothing - then its most likely just a clogged line or somthing simple like that
the washers are raised hydraulically so if it's not coming up it's not getting enough pressure. the fact that you see fluid dripping underneath most likely means theline is partially clogged somewhere
mcanedo92588
Jul 1, 2013 11:27 PM
