help Buying a used car
Old Nov 10, 2005 | 09:32 PM
beefsb89l's Avatar
Default help Buying a used car
sup guys sorry to bother but i need to know about how many miles i should be looking for when i purchase an
a4 98 1.8t quattro
please help and what other problems should i be looking foward in the future ? thanx
Old Nov 10, 2005 | 09:46 PM
flyinb501's Avatar
Default RE: help Buying a used car
Obviously the lower the better. If you have more money you'll get a car w/ lower miles. Its not rocket science
Old Nov 10, 2005 | 10:31 PM
sandman's Avatar
hahahahahhha true flyinb5. i would be cautious when buying a car with more than 70k. this doesnt mean dont buy a car with 90k on it this just means have it throuly checked out before considering the purchace.
Old Nov 10, 2005 | 11:51 PM
Yuikio's Avatar
^^Yep. If you have a firm spending limit, you'd be better off looking at all A4s that fall under that cap instead of a specific model year that you think should cost a certain amount.
Old Nov 11, 2005 | 12:11 AM
Dj Spiel's Avatar
Hi, welcome to forums.
Like the guys said lower the better.
Things to check for.
Water Pump
T-Belt
Control arms
struts
tierods
Any leaks
Ac work
sunroof work
any electrical issues
ALso no mods so if u just wanna drive around point a to point be ok great. if u wanna mod get 1.8T
Make sure u test drive car. listen make sure gears are ok. and that the cats are coughing.
ORIGINAL: beefsb89l
a4 98 1.8t quattro
Old Apr 15, 2006 | 05:33 PM
CanonSnob's Avatar
How would you suggest finding out if the struts tierods are ok. Is there anything paticular that will stand out to show they are not ok?
Old Apr 15, 2006 | 05:46 PM
dan908's Avatar
Struts you should be able to bounce on the front/back of the car and the instant you stop bouncing, it should stop bouncing.
Tierods grab um, they should be tight. Also look at them. Chunks of the bushing missing, damaged, etc. is bad. They should be in good condition and well lubed. And tight.
Eric Strong
Mar 6, 2010 07:39 PM
Woodhead2k
May 22, 2008 02:52 PM
BWillis
Dec 6, 2007 01:09 PM
beefsb89l
Nov 9, 2005 06:37 PM
