HELP! Limp mode, car running like shi*
Old Oct 14, 2005 | 03:49 AM
greenday's Avatar
Default HELP! Limp mode, car running like shi*
Ok so first off my car is a 01 a4 1.8t q m, i have a n75 J valve, K&n panel filter, and Forge DV, boost gauge, otherwise stock AWM.
the problem is when i get on it at all really the engine will go up to about 15-16# then cut back to 5 or so, then im stuck in limp mode where about 7-9# is the maximum i can reach with heavy fuel usage. So something keeps sending my ecu into safe mode. i just removed my test pipe to drop my boost down a bit to hopefully solve the problem, but no luck. every time i reset the ecu and get on it, it will hold at 15# for a couple seconds then cut. when i lived at a higher elevation(thinner air) the engine never hit limp mode, now at sea level it seems i can't keep it out of limp mode. my idle vacuume sits at about 17-20.
could a bad connection on the MAF cause problems? the connector on my MAF is a little funky, could that cause this?
Im getting new plugs tomorrow, maybe a colder plug will help.
i mean for a basically stock car this is some bullshit. im not getting any CELs.
what else might be the problem?
Is there anyone in the South LA/ Beach cities area with a Vag Com or other reader?
one more thing. im thinking i might just be getting some wattered down gas, so where is a good place to buy gas from in the socal area? i have been buying from arrco. any reccomendations? anywhere sell 93? thanks
any ideas or suggestions are appriciated. thanks
Old Oct 14, 2005 | 12:06 PM
CRAZYHAWK's Avatar
Default RE: HELP! Limp mode, car running like shi*
Do a search for Steve Hall Vag-Com Locator.
Read your spark plugs before changing the heat range.
timbassett23
Feb 11, 2013 12:09 AM
jjcrt2
Sep 19, 2009 05:40 PM
x1n54n3x
May 15, 2009 04:53 PM
jrock
Nov 20, 2007 05:15 PM
auditt225
Mar 27, 2007 03:32 PM
