help need with vag codes, thanx
Old Mar 20, 2005 | 10:24 PM
  #21
rnbguy's Avatar
Default RE: help need with vag codes, thanx
oopsi mean 4 wires anyone know which wire in the audi represents what/
Old Mar 20, 2005 | 11:03 PM
  #22
Jestnomen's Avatar
6th Gear
Generics are typically a bad idea. At least tell me you are going to solder it?
Old Mar 20, 2005 | 11:05 PM
  #23
rnbguy's Avatar
for sure, im not that lazy , do u know what size socket id need to remove it?
Old Mar 20, 2005 | 11:22 PM
  #24
Doose's Avatar
22mm, split side.
Old Mar 21, 2005 | 03:09 AM
  #25
rnbguy's Avatar
MAN THAT WAS THE BIGGES WASTE OF MONEY !!!... i got rid of the sensor error code but so what, im still getting the other error code, even after taking it for a spin for 10 minutes, surely the cpu will adapt by then
00561 - Mixture Adaptation
14-00 - Adaptation Limit (Add) Exceeded
which is the main one i wanna get rid off, its the only error code i have, and cant get rid of it, my cars making a unburnt fueel smell still...
Old Mar 21, 2005 | 10:36 AM
  #26
rnbguy's Avatar
well i cleared the codes in last hope, this morning, ive been driving since then which is a few hours, and have had no fault codes returned,i hope it stays this way, ive noticed the smell is alot less and the fuel consumption is much better... finger crossed..
btw thanx to those who helped
Old Mar 22, 2005 | 08:56 AM
  #27
david9999's Avatar
Should be OK.
when your 0x sensor starts to deteriorate, the ECM compensates by changing the lambda. When the 02 sensor dies, the compensation limit of the car is exceeded and it says that the compenstions is out of range.
Out of interest, I see that ECS is selling a VW 02 sensor for about 30 dollars. Has anyone tried it?
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
