Help! Rear brake tool stuck in caliper
Old Nov 28, 2007 | 04:59 PM
Notahondaowner's Avatar
Default Help! Rear brake tool stuck in caliper
So im on the last set of brakes, did both fronts, pass rear, now my caliper tool is stuck between the piston and caliper. I cant turn it counter clockwise to get it to come loose. I just bought this damn tool and really dont want to cut it in half. WTF can i do
Old Nov 28, 2007 | 05:02 PM
techbod's Avatar
Default RE: Help! Rear brake tool stuck in caliper
if its the tool im thinking of it has a handle to lock it up ans a spanner point to undo it ( used for left hand thread ) the silver bitI guess you got the 2 pins locked in the piston
Old Nov 28, 2007 | 05:07 PM
its this one, im F'd arent i, yeah its locked in the piston
http://www.autozone.com/selectedZip,.../selectZip.htm
Old Nov 28, 2007 | 05:13 PM
bob12312357's Avatar
If its like a C-clamp and it won't turn the other way try large channel lock plyers to give you leverage and get it to turn. Why not just use a 10 dollar C-clamp for the job?
Old Nov 28, 2007 | 05:15 PM
Figured it out, im retarded, never done rear pads before. Apparently you have to use a wrench on the lower part once it becomes locked. thanks for all the advice. Im gonna go change my underwear, drink a beer, and finish putting my car back together.
Old Nov 28, 2007 | 06:37 PM
Papachristou's Avatar
ORIGINAL: bob12312357
because rear pistons must be turned at the same time as being retracted... prettty much requires the use of the brake tool
and i cant tell u how many times stopping for a beer helped clear my head and ease my frustration! good call!
Old Nov 28, 2007 | 07:41 PM
ORIGINAL: Papachristou
thank you for this info as that is definitly an intresting nuance of this car. This way i'm not smashin my head against the wall when i gotta do mine.lol
greenday
Dec 16, 2008 05:38 PM
Eppic00a4
Mar 16, 2008 08:15 PM
Notahondaowner
Nov 20, 2007 11:41 PM
eliTTe
Jun 12, 2007 01:31 AM
onepoint8tee
Jan 6, 2006 09:38 PM
