how to change oil
Old Jan 3, 2006 | 12:21 AM
juice88's Avatar
Default how to change oil
does any1 know where i can find instructions on how to change oil on our a4s. its like i can do clear corners and put in a snub mount but i cant even change my oil
Old Jan 3, 2006 | 01:57 AM
John_E's Avatar
Default RE: how to change oil
There is lots of information about this on PassatWorld.com, both in the garage and in the regular forums.
The biggest pain is mastering the belly pan; the rest, i.e., filter and drain plug, are really no worse than in most other cars. If you have a 1.8T, disconnecting the air inlet hose from the throttle body greatly improves access to the filter. (You are, of course, using the larger 068-115-561B, instead of the original 06A-115-561B???)
Old Jan 3, 2006 | 02:41 AM
headshok2002's Avatar
I do everything from underneath the car... ... well except for add oil...
I tried doing the filter from the top, by moving the coolant resevoir... I won't be doing that again. Just jack up the car, and all will become clear... It isn't hard at all. But yeah, make sure you use the big filter.
Old Jan 3, 2006 | 02:44 AM
flyboy's Avatar
Oh come on man, filling the oil is the most fun part from under the car. It show you have flexability.
Old Jan 3, 2006 | 02:52 AM
seahawkfan94's Avatar
Haha that'd be funny to see...
Old Jan 3, 2006 | 03:48 AM
onepoint8tee's Avatar
No wonder the snub took you 48 hours... That would equal about $5,000 in labor at the dealer you saved!!! Just kidding dude... But... uhh... Well there is a drain plug which can be found at the bottom of the engine, and a fill plug which would be located at the top of the engine if memory serves me correctly, then im pretty sure there is something called an "oil filter" which kind of blends in with the rest of the parts cuz its big, round, and says "oi filter " on it.. Youll want to unscrew that counter clockwise, and replace in a clock-wise fashion.. Oh I forgot, dont forget to drain the oil into a container for proper disposal at your nearest advance auto parts or napa... Put drain plug back on, refill oil up to the top line on the "oil dipstick". If you need me to call and talk you through it pm me!
Old Jan 3, 2006 | 02:13 PM
Slowb5's Avatar
^ wiseass ...but yeah dude, its pretty simple. almost self explanatory.
use mobil 1 fully synthetic....w/e weight you prefer.
o, and use the audi filters only...all else are crap and may spring a nasty leak.
Old Jan 3, 2006 | 02:17 PM
Kellya4's Avatar
The belly pan is the worst pat of the process, but even w/ the car lowered, i don't have to put it on ramps or anything, the filter is right in front and easy to get at.
Old Jan 4, 2006 | 12:03 AM
juice88's Avatar
ORIGINAL: onepoint8tee
now now, dont be an ***. the only reason it took me that long is because i didnt have the proper tools and had to weight till the next day. and thanks every1 else for the input.
Old Jan 4, 2006 | 12:05 AM
juice88's Avatar
hahahahahah i spelled wait weight. and onepoint8tee, im not complete dumbass when it comes to cars
