how to determine exact engine type
Hi,
Is there a simple way to determine exactly what engine type I hav eon my A4. I know that it is a 1.9TDI - but is it a PD engine, what is that exact BHP etc?? I want to chip the engine but need to know exactly what type I have!
Cheers
Cheers
Cheers - removed the plastic cover and looked yesterday evening and found two sets of numbers
038 103 469R - which I think is just the code for the rocker cover
3103041821 - which I have no idea what this means!
Do these numbers make sense to you? Should I be able to tel the engine type using the VIN number??
Thanks for the help
Thanks for the help
the numbers are part numbers only, you BHP is 115 standard only 2 engine types are in the UK and engine numbers are ( AJM/ATJ ) these letters can be found on the top of the engine just above the fly wheel on the engine casing should you find a different set of letters its probably down to it being made for the USA
Cheers - Looked under the bonnet again and the code on the camshft cover is AVB 2134 ... Any ideas what the bhp is for a AVB engine or where I could find the information?
