how to determine exact engine type
Old May 8, 2006 | 11:38 AM
ballinloughan's Avatar
Default how to determine exact engine type
Hi,
Is there a simple way to determine exactly what engine type I hav eon my A4. I know that it is a 1.9TDI - but is it a PD engine, what is that exact BHP etc?? I want to chip the engine but need to know exactly what type I have!
Cheers
Old May 8, 2006 | 12:41 PM
onepoint8tee's Avatar
Default RE: how to determine exact engine type
It should be on the valve cover on top, on the firewall side, under the black cover that you take off with 3 plastic screws-if you have that.
Old May 10, 2006 | 07:06 AM
Cheers - removed the plastic cover and looked yesterday evening and found two sets of numbers
038 103 469R - which I think is just the code for the rocker cover
3103041821 - which I have no idea what this means!
Do these numbers make sense to you? Should I be able to tel the engine type using the VIN number??
Thanks for the help
Old May 10, 2006 | 08:09 AM
techbod's Avatar
the numbers are part numbers only, you BHP is 115 standard only 2 engine types are in the UK and engine numbers are ( AJM/ATJ ) these letters can be found on the top of the engine just above the fly wheel on the engine casing should you find a different set of letters its probably down to it being made for the USA
Old May 11, 2006 | 07:53 AM
Cheers - Looked under the bonnet again and the code on the camshft cover is AVB 2134 ... Any ideas what the bhp is for a AVB engine or where I could find the information?
Old May 11, 2006 | 08:04 AM
techbod's Avatar
AVB=Audi A4 age 2001 to 2004, 1.9D-TDi PD, BHP 100 at 4000 RPM
Old May 11, 2006 | 08:35 AM
Kool - can I ask another question ... where did you find the information? I didn't realise that I had a PD engine!
Thanks for all your help ...
Old May 11, 2006 | 08:39 AM
techbod's Avatar
its on my database
Old May 11, 2006 | 09:15 AM
Very good ..
Could you recomend a suitable mod chip for this engine? Since I only have 100bhp ....
Old May 11, 2006 | 10:03 AM
techbod's Avatar
modding isn't my area but im sure there are many much more qualified in this area than me and im sure they will help you
doj
Apr 14, 2010 10:24 AM
michaelh305
Aug 4, 2008 11:14 AM
Mac_17
Nov 11, 2007 07:02 PM
Deekster22
Jun 22, 2007 12:43 PM
VolcanicBlackA4
Aug 9, 2006 02:02 PM
