How to remove abs sensor
How to remove a abs sensor? just pull? is it press fit in the knuckle hole?
I'm having the abs issue at low speed when stoping. I want to clean them but can i pull them out or will i to remove CV, hub, etc....
I'd love to and i did just that, but 1 out of 5 time it return nothing or doesn't work. The 1 or 2 i found about it didn't mention exactly how to remove it. Search is having issue on this board, database is too big or server lacks CPU power, could be a badly configured DB, who knows, anyhow i haven't had much luck with search.
I tried to search with "abs sensor" and "removing abs sensor" Like i said 4 out of 5 times i received a popup saying "the system could not find any record".
I just click on the link posted byonepoint8tee again and i received that popup again "the system could not find any record". Some thingis wrong with DB, it is slow even if it returns results.
Anyhow thanks.
Anyhow thanks.
jkjersey
B7 Models
Jun 17, 2013 09:31 AM
