How to remove abs sensor
Old Nov 4, 2007 | 04:37 PM
eleblanc's Avatar
Default How to remove abs sensor
How to remove a abs sensor? just pull? is it press fit in the knuckle hole?
I'm having the abs issue at low speed when stoping. I want to clean them but can i pull them out or will i to remove CV, hub, etc....
Old Nov 4, 2007 | 04:46 PM
hiwords's Avatar
Default RE: How to remove abs sensor
do a search
Old Nov 4, 2007 | 06:55 PM
eleblanc's Avatar
I'd love to and i did just that, but 1 out of 5 time it return nothing or doesn't work. The 1 or 2 i found about it didn't mention exactly how to remove it. Search is having issue on this board, database is too big or server lacks CPU power, could be a badly configured DB, who knows, anyhow i haven't had much luck with search.
Old Nov 4, 2007 | 07:30 PM
onepoint8tee's Avatar
ORIGINAL: eleblanc
Youlack searching powers, or maybe your fingers are badly configured? [8D]
CLICK
Old Nov 4, 2007 | 07:56 PM
eleblanc's Avatar
Thanks,
But my previous search using "abs sensor" didn't got me lucky.
Old Nov 4, 2007 | 08:03 PM
CLX's Avatar
CLX
Zombie Defense Force
You have to be specific with this search engine, it craps out if you're too general
Old Nov 4, 2007 | 08:13 PM
eleblanc's Avatar
I tried to search with "abs sensor" and "removing abs sensor" Like i said 4 out of 5 times i received a popup saying "the system could not find any record".
I just click on the link posted byonepoint8tee again and i received that popup again "the system could not find any record". Some thingis wrong with DB, it is slow even if it returns results.
Anyhow thanks.
Deployer609
Apr 28, 2015 09:00 PM
Eric_C
Jul 10, 2009 11:54 AM
speedys4
Dec 1, 2008 01:14 PM
bhj0887
Nov 25, 2005 11:29 PM
