Im Runnin Rich Help me Out!
Old Jun 10, 2005 | 04:01 AM
SavageA4's Avatar
Default Im Runnin Rich Help me Out!
Sup i got a 97 a4 1.8t..love it, but my check engine light went on and my obdII says bank 1 runs rich does anyone know what i can possibly do or get done to fix this, i have already swapped the air filter didnt seem to help much, also i get bad gas mileage and reduced horsepower especially at low rpms, also my rpm gauge jumps when i cold start..any input is appreciated thanks guys
Old Jun 10, 2005 | 09:40 AM
david9999's Avatar
Default RE: Im Runnin Rich Help me Out!
Print out the codes.
Most likes it is one or two bad pre-catalytic converter oxygen sensors.
If bank one is rich, most likely I'd replace the ox sensor on that side
Old Jun 10, 2005 | 09:43 AM
TomRitt's Avatar
yup o2 sensor or possibly maf
Old Jun 10, 2005 | 11:30 AM
insuite's Avatar
O2 sensor's really easy to replace and that's most likely your culprit. I just went thru the same thing.
Old Jun 10, 2005 | 07:06 PM
SavageA4's Avatar
thanks guys ill try that next..do you have steps for replacin the o2 sensor diy or a link you can send me thanks for tha help
Old Jun 10, 2005 | 10:48 PM
david9999's Avatar
Search the archives, or spend 15 dollars on a Haynes manual from Pepboys.
You will need the appropriate wrench for 0x sensor removal and a good strong arm. When you put the new one in, use antiseize grease on the threads.
See if you can find someone with a vagcom and check the sensor output.
Old Jun 11, 2005 | 12:25 AM
insuite's Avatar
If you plan on doing some of your own work ... get a Bentley manual. It's worth the $80.
incrementalg
Apr 1, 2008 10:22 PM
Drocka4
Mar 31, 2008 01:29 AM
Big Daddy
Jul 27, 2007 03:52 AM
audisloff
Jan 11, 2006 08:28 PM
EricGT4
Apr 9, 2005 01:22 AM
