INNER tie rod ends???
Old Sep 27, 2005 | 05:30 AM
BFlan2001's Avatar
Default INNER tie rod ends???
anybody replaced theirs? after replacing my outers i've noticed that there is still a very slight clunking sound if you go over bumps at just the right speeds...i'm going to replace my inners and i'm really hoping it's as easy as doing the outers was....anybody have any tips for me?
Old Sep 27, 2005 | 12:53 PM
jukeit's Avatar
Default RE: INNER tie rod ends???
Think it's the inners? Could it be your control arms?
Old Sep 27, 2005 | 01:21 PM
clconversion's Avatar
you can not buy the inner seperatly they come with the outers
Old Sep 27, 2005 | 09:47 PM
sdaudi's Avatar
how do you check if the control arms are busted? i also have the 'clunking' problem. i changed the tie rod ends but the clunking noise is still there when i go over bumps.
Old Sep 28, 2005 | 02:02 AM
BFlan2001's Avatar
ORIGINAL: clconversion
do you mean they only come with the whole tie rod assembly? if that's the case, that kinda sucks, cause i just spent a good amount of time and money into replacing my outers....i had my control arms checked a couple times but both mechanics told me they were fine....i have a feeling i may never find the root of this clunking....[:@][:@][:@][:@][:@][:@][:@]
Old Sep 28, 2005 | 02:29 AM
ecksman's Avatar
could be ur ball joints, my car does the same thing. after a very credible mechanic drove he said thing, remember hearing about a ball joint recall
Old Sep 28, 2005 | 03:35 AM
flyboy's Avatar
I thought the inners were part of the rack.
Old Sep 28, 2005 | 12:56 PM
jukeit's Avatar
Your mechanics probably gave the control arms a couple of twists to see how stable they were. Mine feel stable too when I try and twist them back and forth; however, the ball joints could still be jacked and you won't have much play with that twisting motion because the back end of the control arms with the bushings are still solid. After I replaced my outer tie rods, I compared the old and the new. The old ball joint was completely f'd. It felt all sloppy and loose when you wiggle it around. I'm positive my control arm ball joints are equally as bad. I have to replace my control arms sometime in the next 6 months. When I do and if my clunking is gone, I'll let you know.
norcal89451
Apr 8, 2013 09:15 AM
01afour
Sep 24, 2008 02:59 PM
Quattro_1.8t
Jan 19, 2008 04:12 PM
trey
Oct 3, 2005 11:50 AM
BFlan2001
Apr 5, 2005 11:00 AM
