INSTALLING DROPIN K&N FILTER
Old Feb 27, 2006 | 12:02 AM
KarlMarx's Avatar
Default RE: INSTALLING DROPIN K&N FILTER
I'm not at home right now to look at mine, but try this. Remove the two screws indicated, and lift up. I think that's your airbox... Give it a try... [&:]
Old Feb 27, 2006 | 12:07 AM
Dr!ven's Avatar
yeah, like karlmax said unscrew those 2 and you should be able to open it. if you wanna take the whole thing off just the hoses in the front. btw, the long plastic intake on the top does come off.
Old Feb 27, 2006 | 02:52 AM
StepUpProductions's Avatar
alright i had the same problem... heres the solution, basically that hose thats running parallel to the seam of the air filter box, should unclip out of little holes and pull it up towards you. on that same line there should be a black little like 35mm fil canister looking thing attached to a hose that is right above the airbox if your looking straight in from the front of the car. unclamp the hoseclamp on the hose... (i just used needlenose pliars) but you can pry it up with anything like a knife or something. one the hose clamp is off... pull the hose off the black 35mm film canister looking thing. from there, unscrew the airbox, and you should be able to push the aibox open towards the engine. now remember that the k&n filter sits on the lip of the part of the airbox you moved and unscrewed... it took me a while to figure it out but make sure the ridge of the filter lines up with the lip on the air box... then hold it in place through the air inlet as you close the box and tighten and then put everything back together... see if that helps
id take pictures to help out but i cant get into my engine on account i hit a deer last night and fucked my car up
Old Mar 5, 2006 | 08:49 PM
mauricewong's Avatar
Hey guys, .. thanks for the tips. I tried everything you said, and sure as it is it worked out.
I finally got the K&N filter in the car and it wasn't too bad but it's not straight forward for any newbs like me.
Anyhow, i posted some pictures that most newbs would wanna ask .... it shows some of the instructions on the parts where i was lost or was stuck.
Cheers.. .. !!
2-5 HP ? ???? <-------- i seriously doubt it. But it's still good to know ... you don't have a paper filter........
Cheers boys...
Maurice
email me @ nastypooh99@hotmail.com if your stuck ... this is for a 2003 ....2004 A4 installation of a K&N filter.
Old Mar 7, 2006 | 02:14 AM
liquidxit2's Avatar
Im going to ask my nearby audi expert but does the filter increase at least increase throttle response? or gas mileage?
Old Mar 7, 2006 | 02:27 AM
1-3 hp gain, but if you can notice that... i dont know, your special or something... i have one in my car, i mean throttle response, maby a little. but what i also like about it is it makes the induction sound a little better and you can hear the DV slgithly better too which is cool. its just good to know you have something thats flowing pretty good in there when you up your boost
Old Aug 1, 2007 | 04:29 PM
ntalec's Avatar
After looking for awhile on the net Ifound this link.
How to Change Air filter B6 2004 A4. Hopefully it will be easier to find for the next newby.
http://www.a4mods.com/index.php?page.../pages/kn.html
Old Aug 1, 2007 | 04:53 PM
  #18
EVOLA4's Avatar
LOL! I about laughed my a$# off when i saw the post from ntalec (above me). That is usually the first place I look for good advice on diy's not to mention there are some other good links on here if you do a search. congrats on finally getting it done though. When i installed my cai, the hardest part was getting the old intake out. those things just require a little muscle and they come right out.
Prizmatik
Sep 20, 2008 02:04 PM
4.2a6
Mar 1, 2008 09:33 AM
Leifer
Oct 2, 2007 08:10 PM
Pablo_Ottawa
Apr 19, 2007 12:34 PM
Decivs
Sep 11, 2006 05:13 PM
