interesting idea
Old Apr 8, 2005 | 12:59 AM
jblum's Avatar
Default interesting idea
Turbo on 99.5 1.8 is broken (chipped blade?). Audi will replace it under the 7 year warranty (in California) if the turbo failure either makes the CEL come on, or makes the car fail a smog check. Is there anyway I can make either of these happen? (I'm desperate)
Old Apr 8, 2005 | 01:00 AM
David_K's Avatar
Default RE: interesting idea
hollow out the cat
run leaded gas
Old Apr 8, 2005 | 01:03 AM
jblum's Avatar
Yeah, but its gotta look like the broken trubo made it fail.
Old Apr 8, 2005 | 01:05 AM
David_K's Avatar
leaded gas is your best bet then. itll fail miserably
Old Apr 8, 2005 | 01:09 AM
PandaXpress's Avatar
hollow cat and hopefully your air filter and oil is dirty
Old Apr 8, 2005 | 01:10 AM
jblum's Avatar
Will putting leaded gas in my car permentently ruin anything on the car (don't care if it ruins the turbo, but anything else)?
Old Apr 8, 2005 | 01:36 AM
TomRitt's Avatar
run the turbo with no oil, it will def throw a cel after the turbo get destroyed
Old Apr 8, 2005 | 01:39 AM
ImolaS4's Avatar
Remove the clamp from the exhaust side so the return leaks.
Then put it back on after you get the CEL.
That's the only idea I have that might work.
Old Apr 8, 2005 | 01:52 AM
audiboy1618's Avatar
Thats a really good idea, imola.
Old Apr 8, 2005 | 01:56 AM
wont the CEL go away after u put the clamp back on
