K04 upgrade worth it for k03s a4?
Old Oct 20, 2007 | 06:25 PM
cincyTT's Avatar
I'm make believe
Default RE: K04 upgrade worth it for k03s a4?
you had a turbo rated 20hp less than a ko4 so you would notice more of a difference. His it the same dimensions so little gain will be noticed and not worth it.
Josh, im sure a lower tq turbo like a t3t4 would be fine on a tip car. Get you 300hp and 250-260tq and be all good.
Old Oct 20, 2007 | 06:32 PM
Audi_Skydiver's Avatar
Oh man... no I am going to have to start searching on that one... Thanks a lot cincy, thanks a lot.
Not to thread jack but do you know any good links to look around for info on that? I just tried searching and its a bunch of confusing stuff that doesn't really answer my question.
Josh
Old Oct 20, 2007 | 06:43 PM
cincyTT's Avatar
I'm make believe
pagparts.com
atptubo.com
himni-racing.com
vwvortex 1.8t section's 1.8t dyno thread
A 50trim with a .63 turbine will have a good amount of lag, but that makes hp and less tq which the tip and stock rods need. You maybe able to get away with a .48 housing for faster spool, but im not sure. 300fwhp is had about 18-20psi and still in the 200's in tq.
Old Oct 20, 2007 | 06:45 PM
what about Awhp?
Josh
P.S. Can you pm me that info? I don't want to take over this thread.
Old Oct 20, 2007 | 06:59 PM
cincyTT's Avatar
I'm make believe
you got pm
Old Oct 20, 2007 | 07:47 PM
tdn's Avatar
tdn
cincy, whats the max power achievable with a k03s?
i've heard of k04s getting 260-275hp with dahlback and giac tuning. this is a k04 with all the supporting mods, injectors, fmic, etc.. if i were to get larger injecters, fmic, etc.. and the proper tuning for my k03, how much power would i be able to get while keeping reliability.
i don't have the cash to spend on a bt at the moment, and i would be fine with 210awp and 260hp.
Old Oct 20, 2007 | 08:07 PM
Did you get my last PM Cincy?
Josh
Old Oct 20, 2007 | 10:57 PM
  #18
audiholix's Avatar
Cincy,
Thanks for the reply. My next question would be reliability. Is the gt28rs or t3 60 trim considered pretty reliable for daily driving? I don't want to run into constant problems with the motor or turbo since I need this car as a daily driver. I know stock internals are good for 300whp but it seems like a high number for daily driving. Car has 61k right now and most the maintenance has been done. Cam chain tensioner, timing belt, water pump, fuel filter, etc. Thanks for the clarification.
Old Oct 21, 2007 | 02:43 PM
  #19
cincyTT's Avatar
I'm make believe
ORIGINAL: tdn
From the fwd dynos i have seen, most ko3s make just over 200whp with basic mods (intake, exhaust, ic) and about 210whp for a ko4. The power band is the same so not worth the timing bump. For a 00+ car, w/m injection is a better way to spend money since you can increase timing since more boost isnt getting you any more power past 20-22psi.
Old Oct 21, 2007 | 02:46 PM
  #20
cincyTT's Avatar
I'm make believe
ORIGINAL: audiholix
Cincy,
both are full garrett turbos and if taken care of (given proper cooling and not over boosted) you can see 80-100k miles from them
kakluote
Dec 5, 2012 04:06 AM
to4xxx
May 19, 2012 08:34 PM
aud1
Jun 30, 2011 03:13 AM
.:FMD
Feb 5, 2011 06:38 PM
chosos
Jan 27, 2009 03:11 PM
