MAF READING...PLEASE HELP...
Old Jan 9, 2006 | 09:46 PM
A4_1.8_20v's Avatar
Default RE: MAF READING...PLEASE HELP...
sorry for the late reply everyone...
a fault code appeared, i think it was along the lines of maf voltage low or sumthing, the clever mechanic decided to delete the codes before i could take note of them!!!. i also had something along the lines of throttle or fuel adaption too high...
i really am sorry for the lack of information, but i did feel better after ringing the mechanics neck.....lol....
thanks
Old Jan 9, 2006 | 09:48 PM
A4_1.8_20v's Avatar
also, what should a good MAF reading be at idle???
Old Jan 9, 2006 | 10:13 PM
dafrazi's Avatar
27.78 g/s at idle seems high. I get around 3 g/s. Normal range from Vag-Com says 2.5-3.5 g/s at idle
Old Jan 9, 2006 | 10:23 PM
A4_1.8_20v's Avatar
thanks.
so if this reading is high does that mean that because the maf is telling the ecu that more air is going in, the ecu throws in more fuel and this is causing my terrible gas mileage!!!???!! i.e. is this causing my engine to run very rich??
also this makes sense, because the gas mileage is really bad even when driving the car like a granny!!!
any further contributions???
Old Jan 9, 2006 | 11:45 PM
dafrazi's Avatar
Yes, I'm thinking your car is running rich. Something with the MAF isn't right. Did you have any codes when you Vag'd your car? Is there a soot stain on your rear bumper?
Old Jan 10, 2006 | 01:24 AM
david9999's Avatar
Idle should be approximately 3 gram per sec.
Scaryfatkid
Jun 1, 2010 04:17 PM
AudiCross
Apr 16, 2010 04:15 AM
Yerfdog006
Mar 17, 2007 08:19 PM
Hecareth
Apr 2, 2005 05:24 PM
blades
Oct 8, 2004 09:04 AM
