The Most Expensive Bolt....Need Help!!
Hmmm.....Hate to say it but I pretty sure cincy is right it looks just like the coolant line fitting and bolt. I found a picture of the coolant line bolt and fitting and it looks just like the one arif has. Does anybody know if this one will work?? -----> http://www.atpturbo.com/Merchant2/me..._Code=ATP-FTG2
If i was you, i would just get a bolt and plug that hole and then get a pressure signal from somewhere else. Something like this will work.....
Look at the line on the far left side of the pipe, it goes to the n75
The problem with getting a pressure source from some where esle is that its farther away from the turbo. if there is a leak or something it will cause the turbo to spike.
sm937
Jan 21, 2013 10:19 AM
Cubanator
Nov 13, 2012 04:26 PM
