The Most Expensive Bolt....Need Help!!
Old Nov 8, 2007 | 03:54 PM
bob12312357's Avatar
Default RE: The Most Expensive Bolt....Need Help!!
The kit goes for like 2 grand so i think 1 grand is fair. lol
Old Nov 8, 2007 | 08:22 PM
ZaneGrey04's Avatar
Hmmm.....Hate to say it but I pretty sure cincy is right it looks just like the coolant line fitting and bolt. I found a picture of the coolant line bolt and fitting and it looks just like the one arif has. Does anybody know if this one will work?? -----> http://www.atpturbo.com/Merchant2/me..._Code=ATP-FTG2
Old Nov 8, 2007 | 08:32 PM
cincyTT's Avatar
I'm make believe
your thread pattern is going to be metric, so no, no english standerd bolt will work.
Old Nov 8, 2007 | 08:36 PM
cincyTT's Avatar
I'm make believe
If i was you, i would just get a bolt and plug that hole and then get a pressure signal from somewhere else. Something like this will work.....
Look at the line on the far left side of the pipe, it goes to the n75
Old Nov 8, 2007 | 08:40 PM
cincyTT's Avatar
I'm make believe
Or if you want to tap into a hose
Old Nov 8, 2007 | 08:41 PM
ZaneGrey04's Avatar
The problem with getting a pressure source from some where esle is that its farther away from the turbo. if there is a leak or something it will cause the turbo to spike.
Old Nov 8, 2007 | 08:43 PM
ZaneGrey04's Avatar
that last pic you posted would work since its right after the turbo where can i get those taps?
Old Nov 8, 2007 | 08:50 PM
  #18
cincyTT's Avatar
I'm make believe
^ click
Old Nov 8, 2007 | 08:54 PM
  #19
ZaneGrey04's Avatar
That might be what I have to do....First Im going to go to the hardware store tomorrow and see if they have anything that will fit.
  #20
cincyTT's Avatar
I'm make believe
Lowes usually has way more metric bolts than Home Depot... just fyi
chippe
Jul 21, 2010 03:55 PM
audiota
Sep 18, 2005 03:44 PM
