Need help with fault codes
Old Oct 26, 2007 | 09:21 PM
Trey25's Avatar
Default Need help with fault codes
16795 -Sec.Air Inj.Sys. Incorrect Flow Detected
17536 -Long Term Fuel Trim mult.,Bank1 System too Lean
17538 -Long Term Fuel Trim mult.,Bank2 System too Lean
17544 -Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
17546 -Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
17549 -Load Calculation Cross Check Range/Performance
The car runs smoothly once the revs are up but idles rough, and never stalls. What could be the cause(s) of the lean mixture? What the difference between the two sets of lean codes, aren't they saying the same thing? About a month ago I got some codes saying the exact opposite. There was a rich mixture and another code about MAF circuit open/bad ground. I thought the MAF was the problem but now with these new codes saying the exact opposite I'm even more confused. Thanks in advance.
Old Oct 26, 2007 | 10:50 PM
hiwords's Avatar
Default RE: Need help with fault codes
lean means not enough fuel. i think that secondary air injection has alot to do with it. most likely a bad pump. also try cleaning the MAF with electronic cleaner
Old Oct 27, 2007 | 12:38 AM
Trey25's Avatar
Well I figured out whats wrong. I was just heading down to the store when the car just died on me. Luckily there was no traffic so I just coasted to a halt directly in front of the store, yea I know how convenient. It crank and start then just die so I pretty much figured its just not getting fuel. So I said let me take a look at the MAF before I call a tow truck to get back to my house less than a mile away. I popped the hood and immediately saw that my ebay intake was disconnected from the throttle body. I tightened everything back up and my car is back to its old pig rich self. What a relief...I'm still gonna change out the maf and precat sensors, eventually.
Old Oct 27, 2007 | 12:50 AM
hiwords's Avatar
lol well that's good.
m.c.
May 2, 2012 01:40 PM
PandaXpress
Jul 25, 2009 10:47 AM
1Move
Dec 1, 2007 05:37 PM
mitao2000
Aug 30, 2006 11:53 AM
BaconBait
Aug 8, 2005 08:21 PM
