Noise
Old Sep 3, 2006 | 01:44 PM
david9999's Avatar
Default RE: Noise
By the time your bearings get that hot, your wheel will fall off. Bearing noise is constant, but gets louder when you turn the wheel slightly away from the side making noise and gets softer when you turn toward the noise.
Old Dec 2, 2006 | 04:30 PM
gododgers05's Avatar
Default RE: Noise
I have the same problem...I replace the rotors, pads and bearings and for a couple of hundred miles it was fine, but now it's starting to make noise again and the rotors even started to get that stupid rust around the edges. if the problem is the calipers sticking is there a way to fix them with out replacing them? because those things aren't cheap.
rahip4567
B8 Models
Nov 13, 2019 04:04 AM
kenman
Sep 12, 2012 02:34 PM
Schlampah
Jan 27, 2011 08:24 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
