Noise after oil change...
Old Nov 30, 2006 | 12:29 PM
blueracer17's Avatar
Default RE: Noise after oil change...
Don't know for sure, but I'm sure the filter has an anti drain back valve to prevent the oil from draining out while the engine is off. That's why it doesn't do it at normal start up. Most engines will make noise, when you have an empty oil filter after an oil change. If you want to prevent this, you can either turn it over with the coils disconected,or fill the filter with oil the best you can. Or just live with it, it won't kill the engine. I'm sure the dealers don't go above and beyond just starting the engine. Good luck
eric
www.shoponemotorsports.com
Old Dec 2, 2006 | 01:48 AM
SMoLiK's Avatar
No I havent cranked the engine over with the coils unplugged. Great advice though, thanks!
SMo'
Old Dec 2, 2006 | 03:49 AM
Amze's Avatar
Have you taken 6 years to take an airbox out? Perhaps your cars moching you, i know a thing or two about that
Old Dec 3, 2006 | 07:42 PM
SMoLiK's Avatar
What do you mean by that? If your asking if I have changed the air filter, yes its about three moths old.
SMo'
Old Dec 3, 2006 | 08:58 PM
wood_e's Avatar
I bet if its only a few seconds its just building up auto pressure. I wouldn't worry about it, but you might want to run a bottle of AutoRX through it. You pickup screen might be a little clogged.
Also, use a synthetic oil like Shell Rotella 5w40 synth. It's a good reasonably priced oil with a good additive pack.
Old Dec 19, 2006 | 01:56 AM
SMoLiK's Avatar
Funny thing, I used Castrol 5w40 synthetic this time (and did not charge the filter or crankt the engine over,talkin to some friends and forgot to), the car started up perfectly and hummed quieter then when I used Mobil1 0w40... Since then starting the car seems to produce less initial sound and the car sounds quieter when it idles as well...Might just be my imagination but it seems to rev quieter andsmoother as well... Just FYI for anyone wondering how this went...
SMo'
Old Dec 19, 2006 | 09:07 AM
audinutt's Avatar
I've been using the syntec 5w40 in my 98 1.8t since purchase, I tried M1 once and didn't like how the engine sounded, I agree that Castrol Syntec seems to keep the engine running smoother.
ltom76
Apr 29, 2013 01:13 PM
Itchy
Nov 11, 2011 05:30 PM
guku0701
Dec 15, 2009 07:15 PM
benpa
Jul 12, 2009 11:48 AM
steady
Aug 27, 2007 04:41 PM
