oil bolt wont come loose
Sounds like it has been over tightened. Try slipping a bog closed end wrench over the end of the socket handle to get some extra leverage. And when you put the drain plug back in, use a copper gasket. If you change that copper gasket EVERY time you change your oil, you should not have to tighten the drain plug so tight.
i had that problem too but then i released b/c of the location or the bolt and where i was i was turning it the wrong way. i know that sounds stupid but u might want to try it. u want to go counter clockwise.
sm937
Jan 21, 2013 10:19 AM
Cubanator
Nov 13, 2012 04:26 PM
