oil bolt wont come loose
Old Mar 10, 2005 | 11:21 PM
Dudek12's Avatar
Default oil bolt wont come loose
Iam changing the oil on my 97 1.8T a4 and I cant git the bolt loose can someone help thanks
Old Mar 11, 2005 | 12:01 AM
Doose's Avatar
Default RE: oil bolt wont come loose
Sounds like it has been over tightened. Try slipping a bog closed end wrench over the end of the socket handle to get some extra leverage. And when you put the drain plug back in, use a copper gasket. If you change that copper gasket EVERY time you change your oil, you should not have to tighten the drain plug so tight.
Old Mar 11, 2005 | 11:30 PM
apg96's Avatar
i had that problem too but then i released b/c of the location or the bolt and where i was i was turning it the wrong way. i know that sounds stupid but u might want to try it. u want to go counter clockwise.
savantv
Jun 14, 2012 10:19 AM
moneyfresh
Jun 10, 2012 09:41 AM
mel23816
Aug 3, 2008 08:48 PM
