oil pan removal and reinstallation
Old Dec 8, 2006 | 06:50 AM
gambit's Avatar
Default oil pan removal and reinstallation
Hi, I have a 1996 A4 2.8 V6 and I went over a speed hump (i think this speed speed hump was made for SUV's) and I cracked my oil pan. I'm a complete amateur when it comes to working on cars but i easily removed the oil pan and had a buddy weld the crack shut. I have purchased a new lower oil pan gasket from the audi agents. I would like to know from people who have reinstalled their oil pans if there is anything special i need to do when installing the pan like using any sealants for the gasket or screws. Also is it necessary to torque the screws or can i just make them tight with a normal hex wrench?
Thanks,
Jacques
Old Dec 8, 2006 | 08:14 AM
david9999's Avatar
Default RE: oil pan removal and reinstallation
Not so sure on the 2.8, but on the 1.8 there is a cross member in the way. You need to lift the engine and remove the engine mounts. Not a simple job.
Old Dec 8, 2006 | 08:27 AM
gambit's Avatar
Thanks for the reply. The 2.8 oil pan is not obscured by the cross member like the 1.8. I have already removed the oil pan and had it repaired, it was pretty easy to remove, I only needed to unbolt the sway bar to get access to some of the oil pan bolts. I just need to know if i need any sealants or anything is required when rebolting the oil pan back on to the car.
Old Dec 8, 2006 | 12:37 PM
rayveedub's Avatar
there is a sealant you will need from the dealership, it works as a gasket.
Old Dec 10, 2006 | 01:10 PM
dankhound's Avatar
If you have a gasket that is all you need. The white audi sealant is used in place of a gasket. There is a torque spec but i dont remember off the top of my head. Maybe 80 inch pounds. Its not very high.
browny355
Feb 28, 2011 10:56 PM
rb12
Feb 24, 2011 12:29 PM
99a4wagon
Dec 10, 2010 07:03 PM
Nas0629
Nov 27, 2010 01:21 PM
jebbgr
Nov 11, 2010 03:41 PM
