OK... what am I doing wrong now?
Old May 27, 2007 | 01:51 PM
B5luver's Avatar
Default OK... what am I doing wrong now?
I finally got around to getting out the laptop and trying to get on Vag-com to look at a few things and mainly find the part number for my TCU. First of all I get everything running, com3... port status is ok, but the interface status says 3 - not found or not ready Because of this every time I try to run the autoscan it fails, i'm assuming because this is happening. Any help, I've tried all sorts of drivers I think, but nothing seems to work.
Old May 27, 2007 | 02:03 PM
techbod's Avatar
Default RE: OK... what am I doing wrong now?
change the coms port till its sees it
Old May 27, 2007 | 02:14 PM
B5luver's Avatar
I did that and for the other three ports it instantly popped up saying 'com port status : inaccessible'
Should I switch the usb port I'm using on the laptop? Any other ideas?
Old May 27, 2007 | 02:22 PM
techbod's Avatar
USB is a pain at best of times you need to install a serial port
Old May 27, 2007 | 02:31 PM
techbod's Avatar
the problem with USB are the driver incompatibility with VAG software ( USB and USB 2 ) a serial input resolves this, I had that problem and one min it would read then nothing so I put it down to USB
Old May 28, 2007 | 10:19 PM
B5luver's Avatar
So just find a laptop with serial, or lug a desktop out into the garage then?
thebanger
Nov 16, 2017 03:59 PM
TheLamb
Nov 26, 2011 01:11 PM
RockSteady860
Sep 17, 2011 11:03 PM
turboAUDI77
May 17, 2007 02:51 PM
